14 years agoundesired sidebands on Cyclone IV E PLL output
I am using a PLL in a Cyclone IV E. I have a 20 MHz oscillator connected to a clock-input pin. I am trying to get 200 MHz as the output. For the design, I am using only an ALTPLL megafunction bloc...
14 years agoGlad that you solved your problem. But I also take it that you used a switcher for the 2.5V due to the 22kHz oscillations, and because of this an LDO is a good conservative design approach. Knowing the sensitivity of the PLL's is why I use LDO + LC filters, with large, medium tantalum caps and also a ceramic cap. Best, James
