14 years agoUnderstanding Clocks for Arria II
I am trying to understand the clock signal of the Arria II. What I want to know is: 1. Is there one main clock input signal for the entire chip? 2. Or is there up to 8 main PLL inputs that dr...
14 years agoThank you rbugalho for your insight. Your comments gave me a better understanding of the clock input. I spent some time reading Chapter 5, which brought up more questions than answers.
I understand that there are clock input pins that can drive the GCLK network clocks, but how do I what the input frequency spectrum is? I could not find a Input Clock Frequency Range, in Chapter 5, I did find in Chapter 1, under the PLL Clock Management section : "Supports spread-spectrum input clocking and counter cascading with PLL input clock frequencies ranging from 5 to 500MHz to support both low-cost and high-end clock performance". Can I assume that this in my Input Clock frequencies as well?
