11 years agoUnderstand and solve setup violation in dual domain clock
Hello all,
I have a project where I have two clock: - 50 MHz oscillator for NIOS synthetized on FPGA - 60 MHz oscillator for USB (from UM232H module) used in a custom component attached wtih QSys to NIOS QSys automatically handle cross-domain transfers of signals. I wat to see signals that come and go into USB module with signaltap so I have multiplied by 2 (to 120 MHz) USB clock with a PLL and attached it to SignalTap. Timing requirements are not met because I have ADBUS signals (bidirectional DATA signals for USB) that violate setup timing by -0.684ns If I report Timing Closure Reccomendations with TimeQuest I get: --- Quote Start --- Register the partition boundaries for the path from pin_ft232h_ADBUS[5] to sld_signaltap:aut...rigger_in_reg[5] Issue: Cross-partition Paths From: pin_ft232h_ADBUS[5] To: sld_signaltap:auto_signaltap_0|acq_trigger_in_reg[5] TimeQuest analysis: report timing Partitions that should be merged: Top -> sld_signaltap:auto_signaltap_0 --- Quote End --- What can I do? Attached Timequest details1 Reply
Deleting ADBUS from signaltap seem to remove violation. Are so hard to observe bidirectional pin?
