HAlex
3 years agoUnconnected inputs of Cyclone III
Hello I am using EP3C40F484C8N FPGA in my board. As now I want to remove some components assembled on PCB and connected to the FPGA inputs I want to know what modifications must be done in my Quart...
- 3 years ago
I will leave these pins defined as inputs (for any case) and will assign an internal weak pull up on them.
WZ2
3 years agoHi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
- HAlex3 years ago
Hello
I don't have any further questions - and already marked this issue as accepted solution (to assign weak pull up on input pins for any case).
Thank you.
