Unconnected inputs of Cyclone III
- 3 years ago
I will leave these pins defined as inputs (for any case) and will assign an internal weak pull up on them.
Do you truly mean 'unused inputs' or are you really just referring to 'unused pins'?
Typically I include this setting in my .qsf files:
set_global_assignment -name RESERVE_ALL_UNUSED_PINS "AS OUTPUT DRIVING GROUND"
So that for any pins I don't refer to they just get set as a low output. So no floating inputs or pullups needed.
I'm talking about floating inputs. These are FPGA pins with input buffer (e.g. all GPIO pins) that or not either externally or internally driven, at least by a weak pull-up. Read it as a comment on your previous idea to leave defined inputs without external driver or internal pull-up.
Regarding driving unused pins to ground, I see no adavantage but a risk of inadvertently shorting board signals. I always prefer the default weak pull-up setting. It has been suggested in old application notes to utilize unused pins as additional ground return, this may be useful for old PQFP packages with few ground pins. It's not necessary with BGA or exposed ground pin packages.
- HAlex3 years ago
