12 years agoUnaligned access when trying to reach AXI-LW from U-Boot
Hello, I have a QSYS system, including some Avalon-MM peripherials connected to the AXI-LW interface of the HPS. For testing purposes I tried to read their registers from the serial consol...
12 years agoIt seems that I have to enable the lwhps2fpga bit in the remap register, to remap the address space.
Edit: I still get the same error in uboot. What I have done: - mw remap 0x11 to activate the hps2lwfpga - md 0xff200000 to read the register at offset 0x0 Did I forget something? Edit: Using the address 0xff800000 directly instead of "remap" seems to work. But when I try to read the registers under 0xff200000 everything is blocked. At least it does not reset the whole thing anymore. Do I need to configure anything else to be able to communicate with my peripherals in the FPGA?
