Carlhermann's avatar
Carlhermann
12 days ago
Unable to scan JTAG chain, TCK only 2V
I have trouble with some development board with 10CL006YE144G. While the configuation by JTAG worked a while, the FPGA is no longer recognized by the programmer using Autodetect.  I checked the volt...
  • FakhrulA_altera's avatar
    2 days ago
    Hello Carlhermann,
    Thank you for the detailed testing. Your standalone test confirms that the voltage drop is caused by the older USB-Blaster cable rather than the FPGA or development board.
    A 2.5 V target supply and the 1 kΩ TCK pull-down are supported connections. However, older USB-Blaster hardware revisions used a different MAX3378-based output circuit, while later revisions added buffering. The failing cable therefore appears to have insufficient output-drive margin or may be degraded; this does not indicate that the FPGA is damaged.
    Please continue using the known-good cable. No board modification should be required, and we can consider this issue resolved.
    Fakhrul
