Unable to scan JTAG chain, TCK only 2V
- 1 month ago
Hello Carlhermann,
Thank you for the detailed testing. Your standalone test confirms that the voltage drop is caused by the older USB-Blaster cable rather than the FPGA or development board.
A 2.5 V target supply and the 1 kΩ TCK pull-down are supported connections. However, older USB-Blaster hardware revisions used a different MAX3378-based output circuit, while later revisions added buffering. The failing cable therefore appears to have insufficient output-drive margin or may be degraded; this does not indicate that the FPGA is damaged.
Please continue using the known-good cable. No board modification should be required, and we can consider this issue resolved.
Fakhrul
Quick update - I checked the current consumption on the TCK Pin when connected to 2.5V to be - as expected due to the 1K pull-down - 2.5mA. Additionally, the FPGA was recognized by autodetect again w/o the scope being connected. Maybe the USB-Blasters I tried (both old, used ones) have issues to drive the signal with a 1K being connected? Thus, running quite at the edge of the thresholds (bit less with the scope connected - less than the minimum required by the FPGA...)?
- FakhrulA_altera1 month ago
Hello Carlhermann,
Thank you for the update. The 1 kΩ pull-down on TCK is the recommended Cyclone 10 LP connection, so its presence does not indicate a low-cost or unprotected design issue. Since Auto Detect works again when the oscilloscope is removed, the symptom is more consistent with limited cable-drive margin or TCK signal-integrity/loading than with a damaged FPGA pin.
Please try a lower JTAG clock frequency or another known-good, preferably newer, download cable. Also check TCK at both the header and FPGA pin for reflections or a marginal high level, and verify that no other device is driving the JTAG signals. If needed, the board designer can evaluate TCK damping or a small capacitor based on signal-integrity analysis.
If Auto Detect is stable after lowering TCK or changing the cable, the FPGA is likely not damaged and the case can be considered resolved as a board/cable signal-integrity issue.
Fakhrul- Carlhermann1 month ago
Hello Fakhrul,
I managed to get another USB Blaster to check and this runs well with the TCK signal's high level matching the USB Blaster supply voltage (JTAG connector Pin 4). Additionally, I just connected supply and TCK line with a simple header only to the USB-Blaster cable, checked the TCK signal w/o pull down (looked ok) and added a 1K between TCK and GND, reproducing the decrease in voltage level.
It seeems that the internal level translator either has problems with the 1K's caused 2.5mA current for a high signal (accoring to the datasheet a 1mA output current can cause a 0.4V drop), or this USB-Blaster is a non 2.5V compatible version?
I also checked the output structure and the working one includes in adition to the level shift (MAX3378) an additional line driver (VA244), while the failing one has a direct MAX3378 output to output header connection. Maybe I'm wrong but wasn't there a limitation on some older USB-Blasters regarding the I/O voltage on output side? Maybe the one without the additional line driver is not compatible with 2.5V system (or less than 10K pull downs)?
Maybe I ran into a "never change a running system" or better "never clean up your workspace too much" issue (at least keep working tools within sight) :-D
KR Carlhermann
