15 years agoUnable to reset device before configuration
I am trying to program a EP2S90F1020 Stratix II device using Altera's USB Blaster. I use *.sof file, mode is Passive Serial, and then click on "start". I receive an error message saying "Error: Unab...
14 years agoI still get the same problem, I use Stratix IV board with xxxx.sof (on device EP4SE530H35C2ES).
I use USB Blaster cable with passive serial mode. If I use auto detect, it comes out a selection window (EP4SE530 and EP4SE530ES), I pick the first one, it comes out two devices (EP4SE530 and EPM2210). Then I add file xxxx.sof, it add a new device EP4SE530H35C2ES. I press start, it quickly print out a message Error (209031): Device chain in Chain Description File does not match physical device chain -- expected 3 device(s) but found 2 device(s). I do not know how to continue! I am new to altera. Please help me up. Thank you.
