12 years agoUnable to Program EPCS16 in system
I recently designed and put together my first FPGA board. I can configure the FPGA over JTAG fine, but the EEPROM seems out of reach. If I use the USB-Blaster in AS mode, it fails to get the device...
12 years agoGlad you found your problem. Both methods work. We tend to use Active Serial as you are doing, or use passive serial or passive parallel modes, if we have a CPU that has the flash storage to hold the bitfile.
They all work. Everyone has their preference. We tend to not install the headers in production and use a bed of nails approach. If the header sizes are a problem, we have used custom headers as well, with a breakout board, or bed of nails setup to access them. Regards, Pete
