busanalphaca
4 years agoUnable to get a simulated graph, with a Fatal License Error
I am currently using Quartus Prime Lite Edition 21.1(Windows) under the C drive and got some problems with getting a simulated graph that I've coded with.
It says that
"Fatal License Error"
U...
AR_A_Intel
4 years agoHi
I’m guessing the error in Questa sim. If that the case, could you help re-confirm your environment variable setup again? You need to set your LM_LICENSE_FILE environment variable to point to the license that Intel provides. c:\intel\license.dat or something similar.
You can refer to link on how to set environment variable.
To make this entry, you may perform a windows Search for "System Variables" and then click on "Edit the System Environment Variables" and then click "Environment Variables". Be aware that you must add the entry in System variables, not user variables.
https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/environment-variables.html
Specifying the License for the Questa
