12 years agoUnable to generate hps_isw_handoff folder
I am not sure if anybody has faced the same problem as I. I am on Quartus II version 13.0 sp1 and I found that after generating my soc system in Qsys, there is no hps_isw_handoff folder being generated. It used to be automatically generated in Quartus II ver 13.0. Did I miss out any steps? Thanks in advance.3 Replies
Hi, Dear wala,
I think you need compile you project in Quartus II IDE. Or you can use the command "make sof" in command shell - Altera_Forum
I changed the SoC device to a ES part and as a result I can now see the hps_isw_handoff folder after the full compilation. I think choosing a non ES part will not run the assembler in Quartus II (not supported yet in software) and as a result no hps_isw_handoff folder are being generated. Thanks. - Altera_Forum
--- Quote Start --- Hi, I changed the SoC device to a ES part and as a result I can now see the hps_isw_handoff folder after the full compilation. I think choosing a non ES part will not run the assembler in Quartus II (not supported yet in software) and as a result no hps_isw_handoff folder are being generated. Thanks. --- Quote End --- I meet the same problem. My design uses the Soc device 5CSXFC2C6U23C8 which contains the HPS. After full compilation, it also can't generate the hps_isw_handoff. Why does it occur? who can help me ? If I use the ghrd example, everything is OK.
