11 years ago
unable to create symbol file for current file (Verilog HDL file) in Quartus IIweb13.1
I am unable to create symbol file for current file (Verilog HDL file) in Quartus II web edition 13.1.
Compilation report shows 'Data not available'.
plz help me !
    I am also doing that tutorial and I have the same problem. I created a project (just as instructed). Chitranshvarun, were you able to resolve this issue?
    Perhaps I should add that I am using this EP4CE6E22C8N FPGA rather than one of the recommended FPGAs...
    Thanks in advance,
    Chandran
    Hi Tricky,
    I am trying to run 'My_first_fpga' tutorial on my cyclone III starter board, verilog code is as below:
    // This is an example of a simple 32 bit up-counter called simple_counter.v
    // It has a single clock input and a 32-bit output port
    module simple_counter (input clock , output reg [31:0] counter_out);
    always @ (posedge clock)// on positive clock edge
    begin
    counter_out <=# 1 counter_out + 1;// increment counter
    end
    endmodule// end of module counter
