LHala
7 years agounable to complete the simulation
I received the following messege when running a simulation using # ** Error: Failure to obtain a Verilog simulation license. Unable to checkout any of these license features: alteramtivsim or altera...
Abe
7 years agoOk, since you're using a subscription version of Quartus, I assume you have also purchased the ModelSim license as well. Can you run the following command in Command prompt and post the output here:
lmutil lmdiag -c <path_to_license_file>
or
lmutil lmdiag
and press Enter. This command will try to read your existing licenses and will report if there are any errors. Please post the output here.
Also make sure that the license variables are setup correctly in your system, ie, they are pointing to the correct license file/path.
