fey's avatar
fey
2 years ago
Ubuntu JTAG problem
I have Quartus Lite 17.1 on Ubuntu 20.04. At programmer I don't see my device. When I write lsusb, I saw Altera USB-BlasterII but programmer cant see the device. I looked forums and i tried solutions but nothing could help. Some says edit the rules but I dont even have 51-usbblaster.rules file. When I did jtagdconfig on terminal I'm getting jtagdconfig: command not found. This made me think it may cause of drivers but didnt saw anything about it.
Any help would be appreciated.
  • Hi,
    You will need to check if the board has embedded USB blaster, then only it is possible to use USB type B.
    Aiman
  • I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
  • fey's avatar
    fey
    Ok, now I have connection, thank you.
  • Hi,
    Aiman
  • Additionally, please ensure that the USB blaster II are from Intel authorized distributor.
    • fey's avatar
      fey
      Thank you, it solved for Usb blaster II. But I have one more cable for another FPGA and it uses USB type B 3.0 for programming. What should I do so Programmer can see the device?
  • fey's avatar
    fey
    I have to figure it out without using 23.3 because my project was designed for 17.1 and would be better to use it.
    I'm not sure that I installed USB blaster II driver. Can you give me a link for correct driver?
    Feyza
  • Hi,
    Can you try to unsintalled and re-installed the USB blaster II driver? Make sure to correctly installed the driver.
    Also, can you use latest Quartus version which is version 23.1?
    Aiman
