fey
2 years agoUbuntu JTAG problem
Hi, I have Quartus Lite 17.1 on Ubuntu 20.04. At programmer I don't see my device. When I write lsusb, I saw Altera USB-BlasterII but programmer cant see the device. I looked forums and i tried solu...
- 2 years ago
You will need to check if the board has embedded USB blaster, then only it is possible to use USB type B.
Aiman
NurAiman_M_Intel
2 years agoHi,
Can you try to unsintalled and re-installed the USB blaster II driver? Make sure to correctly installed the driver.
Also, can you use latest Quartus version which is version 23.1?
Aiman
