18 years agouart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated wit...
18 years agoHello,
in the first example, the polarity has been correct for "logic-level" RS232, which is iverted by the MAX232 driver. Now polarity is incorrect. Apart from that, the module is now sending the intended two characters at corrcet baudrate, LSB "9" first, as I could see by Quartus internal simulator. I append my test vector file. Regards, Frank
