18 years agouart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated wit...
18 years agohmm, ok, thanks for the clock info, I've corrected it to:
if (waiter == 13'b1010001011000) //9600 times a second (aprox) I'm using: http://www.maplin.co.uk/module.aspx?moduleno=97733&doy=12m2 and http://www.maplin.co.uk/module.aspx?moduleno=97872&doy=12m2 and its not working. So if your sure it can be done with that cable, then there must be something up with my timing code, as I have the UART_TXD light flashing as it should. Any more ideas about what could be wrong. I'm running hyperterminal set to 9600bps, 1 stop bit, no parity bit, no flow control. Listening on port COM1. And when I switch switch 0 on the fpga hyperterminal picks up nothing. my latest code is:
module test5(input CLOCK_50,
output LEDR,
output UART_TXD,
input UART_RXD,
input SW
reg waiter = 13'b0000000000000; //counter to reduce clock rate
//reg waiter = 13'b0000000000000; //counter to reduce clock rate
reg state = 4'b0000; //current state. 0 = start bit, 1-8 = data bits, 9 = stop bit, other = ended
reg data = 1'b1; //start high = idle state
reg clk_new = 0; //changes the state of an led every time a bit is sent
reg origData = 16'b0101001100111001; //S 9 in ascii
reg currData;
reg started = 0;
assign LEDR = data; //led outputs current data bit
assign LEDR = SW; //led outputs status of a switch
assign LEDR = clk_new; //led shows when new bit is sent
assign UART_TXD = !data; //assert the transmit wire to the data bit
always @(posedge CLOCK_50) //every clock tick
begin
//if (waiter == 27'b111111111111111111111111111) //1/2 times a second
begin
if (started == 0) //have we not started yet?
begin
if (SW) //start if switch 0 is high
begin
started = 1;
currData = origData; //set the current data register to be the original data register
end
end
else //we have started
begin
clk_new = !clk_new; //change clock led
waiter = 13'b0000000000000; //reset counter
if (currData == 16'b0000000000000000 && state == 4'h0) //end of transmit
begin
data = 1'b1; //idle bit
if (!SW) //if switch 0 is low, then reset to not started
begin
started = 1'b0;
end
end
else
begin
if (state == 4'h0) //start bit
begin
data = 1'b0;
end
else if(state == 4'h9) //stop bit
begin
data = 1'b1;
end
else if(state < 4'h9) //data bits
begin
data = (currData & 1'b1); //get first bit
currData = currData >> 1; //right shift, so as first bit is the next bit to send
end
if (state == 4'h9) //update state
begin
state = 4'h0;
end
else
begin
state = state + 1'b1;
end
end //end data left to transmit
end //end started == 1
end //end if (waiter == ...)
waiter = waiter + 1'b1; //inc waiter
end //end always @...
endmodule
