18 years agouart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated wit...
18 years agoHello,
I could verify, that the module doesn't operate fully correct: 1. RS232 data should be LSB first 2. If you have a 50 MHz clock, the baudrate is proabably too inaccurate. Actual Baudrate is 50e6/(0x1555+1) = 9154 Baud (- 4,6 %). By the way, Verilog knows also hex and decimal constants, e. g. 13'd5207. Operation would be much easier using a shiftregister for the UART. Regards, Frank
