18 years agouart communications
Hey, I'm doing a project involving the DE2 FPGA, where I need to communicate with a pc via a serial interface. I have checked the pin assignments file and noticed there are only 2 pins associated wit...
18 years agoOk, after making some posts on a c++ forum i've gained some insight. I'm trying to hardcode the data rate to 9600bps, and am using the following code:
module test5(input CLOCK_50, output [2:0] LEDR, //output LCD_ON, //output LCD_BLON, //output LCD_RW, //output LCD_EN, //output LCD_RS, //output [7:0] LCD_DATA, output UART_TXD, //input UART_RXD input [0:0] SW ); reg [13:0] waiter = 13'b0000000000000; //counter to reduce clock rate reg [3:0] state = 4'b0000; //current state. 0 = start bit, 1-8 = data bits, 9 = stop bit, other = ended reg data = 1'b1; //start high = idle state reg clk_new = 0; //changes the state of an led every time a bit is sent assign LEDR[0] = data; //led outputs current data bit assign LEDR[1] = SW; //led outputs status of a switch assign LEDR[2] = clk_new; //led shows when new bit is sent assign UART_TXD = data; //assert the transmit wire to the data bit always @(posedge CLOCK_50) //every clock tick begin if (waiter == 13'b1010101010101) //9600 times a second (aprox) begin clk_new = !clk_new; //change clock led waiter = 27'b000000000000000000000000000; //reset counter case (state) //switch on the current state 4'h0:begin //in state 0 if (SW) //check to see if switch is high, if so start, else do nothing begin data = 0; //start bit state = state + 1'b1; end end 4'h1:begin //data bits = 00111001b = 57d (9 in ascii) data = 1'b0; state = state + 1'b1; end 4'h2:begin data = 1'b0; state = state + 1'b1; end 4'h3:begin data = 1'b1; state = state + 1'b1; end 4'h4:begin data = 1'b1; state = state + 1'b1; end 4'h5:begin data = 1'b1; state = state + 1'b1; end 4'h6:begin data = 1'b0; state = state + 1'b1; end 4'h7:begin data = 1'b0; state = state + 1'b1; end 4'h8:begin data = 1'b1; state = state + 1'b1; end 4'h9:begin //stop bit data = 1'b1; state = state + 1'b1; end default:begin data = 1'b1; //idle bit end endcase end //end if (waiter == ...) waiter = waiter + 1'b1; //inc waiter end //end always @... endmodule transmits the ascii character '9' at 9600bps 1 start bit, 1 stop bit, 0 parity bits. I set up hyperterminal to those settings + flow control = none. And connected to com1. I run my verilog code and switch the switch to high, but nothing appears on the terminal. I set the data rate on the board to about 1/2 bit a second, so i could watch the leds, and they outputted correctly, so i'm definetly setting data to the correct values. My code looks correct to me, so i'm guessing i am formatting the frame incorrectly. Any help would be really apreciated.
