SYiwe
7 years agotx_bonding_clocks in ATX PLL and RapidIO IP Core
Hi, In my design I instantiate a 4X RapidIO Core and a ATX PLL IP Core. According to Table 12 in RapidIO user guide, I should connect the 24-bit tx_bonding_clocks of ATX PLL to tx_bonding_clocks_chN...
CheepinC_altera
7 years agoHi,
Just would like to follow up with you on this. Thank you.
- SYiwe7 years ago
Thank you for your answer.
Currently I use a single ATX_PLL, and how can I eliminate the negative slacks in timing analysis in tx_bonding_clocks and rx_pma_clk clock region? (As you can see in the picture above).
I already set the tx_bonding_clocks , txclk and rxclk as global clock in assignment editor, the negative slack reduced to -0.371, still result in bit-error in data transmit and receive process.
I will be appreciated if you can give me some suggestions.
Thanks, regards.
