11 years agoTwo CPLDs on one board & ISP
Hi, I am laying out a prototype board that will have two CPLDs on it (a MAX7128S & a 7160S). My intention is that they will be programmed "in system" using a JTAG interface. I plan on...
11 years ago --- Quote Start --- Just a lot easier to prototype using wire-wrap than doing a PCB. --- Quote End --- If you're operating at low-enough clock rates, then sure ... --- Quote Start --- Also, I can re-use my components. --- Quote End --- Fair enough ... --- Quote Start --- I've done a couple of SMT boards, including some 0.5mm pins FPGA's which isn't all that fun. --- Quote End --- You just need more practice :) Note that there are a few places that make SMT-to-through-hole adapters, eg., Schmart Board ... http://www.schmartboard.com/ You could solder an SMT FPGA/CPLD onto one of these and then re-use it. Cheers, Dave
