8 years agoTutorial or user guide on simulating HPS-FPGA system
Hi, Does anyone know if I can find any tutorial or user guide on how to use Modelsim-Altera to simulate an HPS-FPGA soc? I'm able to use vlog to compile the design, however, when I do vsim, man...
8 years agoThanks. It compiles okay. However, I got error loading the design. There are lots of warning about fail to find the design. For example:
# ** Warning: (vsim-3770) Failed to find user specified function 'questa_mvc_sv_hist_dump' in DPI precompiled library search list "C:\intelFPGA\18.0\ip\altera\mentor_vip_ae\common/questa_mvc_core/win32_gcc-4.2.1/libaxi_IN_SystemVerilog_MTI_full.dll ". There is also error message in the command line: C:\intelFPGA\18.0\modelsim_ae\win32aloem>vsim -mvchome C:\intelFPGA\18.0\ip\altera\mentor_vip_ae\common Reading C:/intelFPGA/18.0/modelsim_ae/tcl/vsim/pref.tcl 'env' is not recognized as an internal or external command, operable program or batch file. terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc Then the program got terminated. --- Quote Start --- Hi, Check below link. https://www.altera.com/support/support-resources/design-examples/design-software/qsys/exm-hps-axi-bfm.html Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End ---
