AMass
2 days agoTrying to reach an EPCQ128A thought Cyclone V dedicated pins, after FPGA loaded in FPPx32
Hello.
Considering the configuration in the table below.
| FPGA/HPS | 5CSXFC6D6F31I7 |
| EPCQ | EPCQ128A |
| MSEL | 0b01010 (FPPx32) |
| GSFI CSR addr | 0xC0010000 |
- Configuration
- HPS boot from µSD, loading a U-Boot
- HPS configures a FPGA design containing a Generic Serial Flash Interface (GSFI)
- HPS asserts 'Bridge enable" command
- EPCQ routed on the AS FPGA dedicated pins
- EPCQ/FPGA routage verification
- We firstly tried to test this connection using a Read ID command asseted on the GSFI CSR throughout the H2F-AXI in 0xC0000000 + 0x00010000 and we get the EPCQ ID 0xFF (Expected 0x18)
- Once we will succes in the read ID command, we will proceed to a write command to set our own value, and then read it back to check the commands execution.
- We will repeat several times following a defined scheme.
Is there a way to boot in FPPx32 and then, while in user mode, drive the EPCQ as a master without MSEL modification ?
