8 years agotrue dual port == 2 x M20Ks
Seems like invoking true dual port (2 R/W ports) doubles the M20K resources - is this correct and if so where is it documented? I don't see it mentioned in https://www.altera.com/en_us/pdfs/lit...
8 years agoFrom all the responses I can see that I was not clear enough about the implementation details, further below:
Quartus Pro Version 17.1 - fails same in 16.x Method: IP Parameter Editor IP: RAM 2-Port Words: 512 Width: 32-40 Block type: M20K All else: defaults, except... Operation Mode - 1R1W - 1x M20K - 2RW - 2x M20K - as reported by fitter My project is the IP only with all ports virtual for experimental purposes. I have attached the .qsys file for your perusal. Disregard the name - just build with either operation mode above and you will duplicate my results. Thanks, Tom
