8 years agotrue dual port == 2 x M20Ks
Seems like invoking true dual port (2 R/W ports) doubles the M20K resources - is this correct and if so where is it documented? I don't see it mentioned in https://www.altera.com/en_us/pdfs/lit...
8 years agoHi,
Are trying to say that ->for example, we have used 256 bit in chip memory parameter(i.e 8-bits and 32 bytes) after full compilation Total block memory bits in flow summary is showing 512? No, You need to check the design files and on-chip memory parameters. can you recheck it? you can compare the parameter setting summary reports with attached.https://www.alteraforum.com/forum/attachment.php?attachmentid=15196 https://www.alteraforum.com/forum/attachment.php?attachmentid=15197 Let me know if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
