14 years agoTroubles with recognizing of MAX II
Good day everyone, I have a troubles with programming of MAX II chip , when I try to program this chip, Quartus inform me that "Error: Can't recognize silicon ID for device 1 "! But when I do ...
14 years ago --- Quote Start --- Maybe someone can explain me where is a mistake?:confused: --- Quote End --- Perhaps you are using an old version of Quartus that does not recognize the MAX II device? What version are you using? Create a new project and see if you can select the MAX II device as the target. What kind of JTAG cable are you using? USB-Blaster or parallel port ByteBlaster? Have you tried another cable? Cheers, Dave
