19 years agoTrouble with EPCS64
I am working on a custom design using a Stratix II EP2S15 and a EPCS64 as my configuration device. I am using the Flash Programmer utility to program the EPCS so that it will load my FPGA des...
19 years agoSandyfeet,
Thank you for the quick response. The link that you sent me definitely sheds some light on what the problem is. However the steps defined do not appear to program the .SOF file into the EPCS device. It seems that it only loads the Nios II design into the EPCS device. Are there steps that it doesn't mention on how to program the .SOF and the new .Flash with offset at the same time? Thanks for the help!
