9 years agoTrouble interfacing FLASH pins to GPIO (retro game related)
Hey all, Just got an Altera DE1 dev board using the Cyclone II, and I'm working on a simple test that is literally just connecting the FLASH chip to the GPIO_0 bus. I'm not performing any logic...
9 years agoYou have to create a SIGNAL assignment for an additional signal in the design.
SIGNAL FL_ADDR_TEMP (21 DOWNTO 0); Then let's say you want to access address location 0x24ffff (22 bit wide address though your code isn't using any of the upper bits for some reason): FL_ADDR <= x"24ffff"; FL_ADDR_TEMP <= FL_ADDR; Then the code you have would be: GPIO_0(2) <= FL_ADDR_TEMP(17); GPIO_0(24) <= FL_ADDR_TEMP(16); GPIO_0(4) <= FL_ADDR_TEMP(15); GPIO_0(29) <= FL_ADDR_TEMP(14); GPIO_0(28) <= FL_ADDR_TEMP(13); GPIO_0(5) <= FL_ADDR_TEMP(12); GPIO_0(25) <= FL_ADDR_TEMP(11); GPIO_0(23) <= FL_ADDR_TEMP(10); GPIO_0(26) <= FL_ADDR_TEMP(9); GPIO_0(27) <= FL_ADDR_TEMP(8); GPIO_0(6) <= FL_ADDR_TEMP(7); GPIO_0(7) <= FL_ADDR_TEMP(6); GPIO_0(8) <= FL_ADDR_TEMP(5); GPIO_0(9) <= FL_ADDR_TEMP(4); GPIO_0(10) <= FL_ADDR_TEMP(3); GPIO_0(11) <= FL_ADDR_TEMP(2); GPIO_0(12) <= FL_ADDR_TEMP(1); GPIO_0(13) <= FL_ADDR_TEMP(0);
