15 years agotri-state
I am looking for a Verilog equivalent of a tr-state device (chip-select) on the output pin of my FPGA. I only want to drive a multi-drop bus when selected and go high-impedance when not. What is the ...
15 years ago --- Quote Start --- I am looking for a Verilog equivalent of a tr-state device (chip-select) on the output pin of my FPGA. I only want to drive a multi-drop bus when selected and go high-impedance when not. What is the easiest way to accomplish this? --- Quote End --- Hi, you can do it in this way: module tri_state_test ( in, ena, out); input in; input ena; output out; assign out = (ena) ? in : 1'bz; endmodule Kind regards GPK
