19 years agoTri-state output and OpenDrain-output in FLEX 10KA
Hi All, I don't undestand in FLEX 10KA. How does "Individual tri-state output enable control for each pin" work. How I can select between Tri-state output and OpenDrain output with IDE MAX+plus...
19 years agoYou implement an opendrain ouput by using a Tristate output.:
Pin = tri.out; tri.in = gnd; tri.ena = data; You can find the tri primitive ( AHDL ) in maxplus II at: help->primitives succes, Andries
