Tri-state bus data bus delayed
Registers may be shifted forth and back along the data path during synthesis, but without changing the logic function or latency.
After seeing the RTL and technology map snippets, I wonder where registering has been originally demanded in the code, e.g. which assignments are clocked.
If this "shifting" of registers back and forth along the data path during synthesis happens - I would understand if this was done with a known expected latch in the actual design. But as can be seen in the RTL the latching of the data occurs in the Write and Read state machine blocks ! After the data leaves these SM blocks - there are no other registers in the design !
Why does the Quartus Synthesizer add this additional latch to implement the tri state buffer AND is there any way to prevent the synthesizer from doing this ?
- ak6dn3 years ago
Are you referencing actual clocked registers? Or latches?
Quartus can move registers around and can replicate and/or merge registers as it sees fit.
If you write some clocked logic equations where you inadvertently don't always assign a value to the output Quartus may infer a latch and insert it.
So be very specific in your terminology of register vs latch when describing your logic.
- SDavi93 years ago
Sorry I was referring to the addition of a clocked register.
The problem can be seen clearly in the RTL representation attached : USB429 - usbD birectional output implementation - RTL.jpg
Where the Tri State buffer is connected directly to the output pin usbD[31..0]
Then in the Technology Map View shown in : USB429 - usbD birectional output implementation - Technology Map Viewer 1.jpg
and then expanded in : USB429 - usbD birectional output implementation - Technology Map Viewer 2.jpg
That a clocked register for some reason has been placed between my Mux and the Tri state buffer for some reason.
