14 years agoTransceiver Toolkit Design Example
Hi, I've recently purchased a Stratix V GX Transceiver Signal Integrity Development Kit and I want to use it to transmit and receive data at 10 Gbps so I can study how our optical circuit affects the...
14 years agoThanks for the tip, I used SignalTap to analyze the test example and found that the system is being held in reset. But I don't understand the purpose of the code that does so:
wire system_reset_cnt;
reg system_reset=1'b0;
// Reset Counter to give active high reset to enable offset cancellation
counter_128 cnt_128_isnt (
.clock (C100mhz),
.q (system_reset_cnt)
always @ (posedge C100mhz)
begin
if (system_reset_cnt >= 8'd128)
begin
system_reset <= 1'b1;
end
end
What does the line 'Reset Counter to give active high reset to enable offset cancellation' mean?
