8 years ago
Transceiver Standard/Enhanced PCS on Arria 10 GX (Dev. Kit DK-DEV-10AX115S-A)
i have some problems with test about transceiver on Arria10 GX.
My goal is: check transceiver comunication with different speed.
I have already done a test a 5Gbps with Native PHY with indipendent Tx and RX block with Standard PCS (10bit) and Bitslip. The test was successful.
Now i want to test the comunication at 10Gbps using Enhanced PCS (64bit) and Bitslip. The parallel receved are wrong, but the bitslip shift the word by 1 bit every rising edge. The receved word is wrong, because have more '1' than i send by TX.
it seems that an internal coding is applied to the block, but every block aren't enabled.
My option are:
PCS-PMA interface 64
FPGA fabric interface 64
RX
FIFO mode phase compensation
FIFO partially full threshold :23
FIFO partially empty threshold: 2
Enable Rx data bitslip
Eenable rx_bitslip port
TX:
FIFO partially full threshold:11
FIFO partially empty threshold:2
Any advice?
Marco
