9 years agoTransceiver passthrough in Cyclone V
Hello! I'm having the following situation and I can't figure out how to do it, after reading the documentation and trying some things I decided to come here for help. I need to connect one tr...
9 years agoHello Dave, thank you for your fast response!
Unfortunately, I don't think this is possible in my case. I'm using the transceivers to receive and transmit SDI video, this means there's no room for idle character insertion which is, if I understand correctly, what the rate-match FIFO does, right? I've also looked at Altera's documentation configuration examples and it disables the rate-match FIFO for the SDI examples. Is there something I'm missing? Regards, Sebastian.
