14 years agoTRansceiver CDR Cy IV
Hello:
The CDR has two modes of operation LTR (lock to reference) or LTD (lock to data). The signal rx_freqlocked Receiver CDR lock state indicator ■ A high level indicates the CDR is in LTD state. ■ A low level indicates the CDR is in LTR state. The receiver is fully functional until 2.0GB receiving the correct data, however I noticed that the signal rx_freqlocked in signal Tap is never high (in theory the CDR is still in LTR mode). My question is , is it possible for the receiver to be functional if the CDR is still in LTR and I am just getting lucky or I have something wrong with the probing of rx_freqlocked ? I am sampling the signal directly from the GBX block without any logic in between. The TXCVR spec. says that the CDR ignores incoming data but I am not sure what it means to the receiver output since I am getting the correct data. thank you Ref: Cy IV TXCVR spec Figure 1-15No RepliesBe the first to reply
