12 years agoTop-level entity " " is undefined
I get the error:
Top-level design entity " " is undefined Full Compilation was unsuccessful. 3 errors I tried using methods from previous posts but nothing worked. I named everything the same. Can anyone explain the problem?3 Replies
What posts are you referring to? have you included all the source code in the project.
Hi, May be could you select top level entity : In Quartus II, "Project Navigator", select "Files" tab, right clic and activate "select top-level entity" ... Hope this helps !
enter the first entity name ex ..ece of ur program
add what r all related module related to work lib in that ece... then compile
