15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years ago --- Quote Start --- So, basically.. this is just to create an input port for ADC data to enter to the SGDMA core in the SOPC built block? --- Quote End --- The block is to get the ADC into SOPC Builder as an Avalon-ST source. From there you can make a connection to an Avalon-ST sink. --- Quote Start --- Why is the valid bit asserted all the time? it does not go invalid? then whats the point of having a valid bit? --- Quote End --- Avalon-ST interfaces normally have ready, valid, and data signals. Its generally just easier to include them all. Whether you implement them, depends on what you are trying to do. For a quick-and-dirty test, not implementing them is fine. --- Quote Start --- Since you said the process is quite easy, do you think you can make this component in SOPC and send it to me? i really need to look at examples to learn to do it right, so many things can go wrong the first time. This is very new to me. --- Quote End --- Here's an example from the Stratix II DSP kit. I was connecting this ADC to an Avalon-ST sink that would accept data on every clock, so I did not need to implement backpressure. I was also using an SOPC clock that was the same frequency as the ADC. If your ADC is running at a different frequency, and with a different width, then you could add a dual-clock FIFO to this component, and then you would implement the ready/valid controls based on FIFO status bits. Note: the _hw.tcl file uses a relative path to the .vhd source, since I keep the _hw.tcl files in a scripts/ folder, and the VHDL in a src/ folder for each project. Cheers, Dave
