15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years ago --- Quote Start --- From your previous post, you said i need to design the input port for Avalon ST? I don't quite know how to start. --- Quote End --- The ADC has no support for back-pressure, and it has valid data on every clock, so an Avalon-ST source component is basically; aso_data <= adc_data; aso_valid <= '1'; If you have to use control registers to setup the ADC, then that would involve an Avalon-MM slave registers interface. The next step is to use SOPC Builder or Qsys to create the _hw.tcl file to recognize this component as an SOPC component. Use the templates provided within that tool. --- Quote Start --- Can i use PIO core to supply the stream or a DCFIFO(input from ADC and output to ST sink of SGDMA) ? If i transfer from DCFIFO to SRAM, can i use memory-to-memory configuration of SGDMA? --- Quote End --- You cannot use the PIO component. You need your own custom Avalon-ST component as described above. You should be able to use the SGDMA controller to connect the Avalon-ST port of the ADC to the Avalon-MM interface on the SRAM. Alternatively, you can create an Avalon-MM master for the ADC interface, and use that to write to the SRAM. But in that case, you would need to include rate-matching FIFOs. The SGDMA controller should have that already (or the fabric that gets created will have it). Cheers, Dave
