15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years ago --- Quote Start --- Hi Michael, Read the Altera documentation on SOPC Builder (old tool) and Qsys (newer tool), and the Avalon bus specification. What you want is an SOPC/Qsys system with an Avalon-ST ADC source, an SGDMA controller, an SRAM controller, and an Avalon-MM master (eg. the JTAG-to-Avalon-MM bridge or a NIOS II processor). You will need to design the ADC to Avalon-ST streaming component (its pretty simple though). You can then use the SGDMA controller for Avalon-ST (ADC) to Avalon-MM (SRAM) data movement. Cheers, Dave --- Quote End --- Dave, From your previous post, is a NIOS 2 processor an option in the design? cause you said "(eg. the JTAG-to-Avalon-MM bridge OR a NIOS II processor).". I thought NIOS 2 is used for commanding data movement? For me to get some reassurance, do you think that this design will work on the DE2-115's SRAM at 65MHz? i need to know this before i dig deep into this, as i have limited time to work on this project.:( Thank you. Michael
