15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years ago --- Quote Start --- Note that tSA, tHA and tHD can be as low as zero. My interpretation is that even the UP and LB pulses shown are not needed, it suffices to keep them low during the write burst, along with CE, WE and OE. And then, you only need to make sure tSD is respected relative to the next address change. --- Quote End --- During the write burst operation, can i just keep WEN, CEN, OEN, UBN, and LBN low the whole time? do i really need to pulse LBN and UBN ? UBN = active low upper byte access LBN = active low lower byte access CEN= active low chip enable WEN = active low write enable OEN = active low output enable Michael
