15 years agoTo build a FIFO using SRAM
Hi, I would like to build a DCFIFO using a SRAM chip on DE2-115. Any idea on where i should start? I know SRAM reads and writes on a different clock cycle as the dataIn and dataOut share t...
15 years agoHi Michael,
--- Quote Start --- Is there any DMA IP core in Quartus 2 i could use? or do i need DMA if i am writing to a SRAM? what does DMA do? can i just use a controller(with a up counter for address bus, etc..) ? --- Quote End --- Read the Altera documentation on SOPC Builder (old tool) and Qsys (newer tool), and the Avalon bus specification. What you want is an SOPC/Qsys system with an Avalon-ST ADC source, an SGDMA controller, an SRAM controller, and an Avalon-MM master (eg. the JTAG-to-Avalon-MM bridge or a NIOS II processor). You will need to design the ADC to Avalon-ST streaming component (its pretty simple though). You can then use the SGDMA controller for Avalon-ST (ADC) to Avalon-MM (SRAM) data movement. What are you trying to do with the data? Capture snapshots of data, or continuously stream it somewhere (other than the SRAM)? Cheers, Dave
