17 years agoTiming violations on SignalTap II Analyzer
Hi, I am receiving lots of timing violations on signals crossing clock domains to SignalTap II Analyzer. Should I set false path to all the signals connected to the SignalTap II analyzer? ...
17 years agoYou can create multiple instances in a single stp file that all run on different clocks. Right click in the instance manager and select "create instance". The different instances operate seperately, so you can't trigger one based on the signal of another, but you can however bring out multiple clock domains into a single stp file.
Kevin
