17 years agoTiming violations on SignalTap II Analyzer
Hi, I am receiving lots of timing violations on signals crossing clock domains to SignalTap II Analyzer. Should I set false path to all the signals connected to the SignalTap II analyzer? ...
17 years agoIf you have unrealistic requirements, the fitter will still try to meet them(it has no idea what's realistic). It's possible that could hurt your real requirements, although more often than not it won't. You need to analyze your failing paths. If the only failing paths are these ones you would expect to fail, then it didn't hurt, but if other paths suddenly fail and they're part of your design, then that's a problem.
