17 years agoTiming violations on SignalTap II Analyzer
Hi, I am receiving lots of timing violations on signals crossing clock domains to SignalTap II Analyzer. Should I set false path to all the signals connected to the SignalTap II analyzer? ...
17 years agokaz is right that you should only be sampling data in the same domain as your signaltap. I have had cases where I need to get that data but also look at data in another domain. It would naturally fail timing, but I was fine with that and didn't bother cutting it. The data captured had to be carefully analyzed, since I knew I would be sampling during transitions, but it works.
