15 years agoTiming simulation
Hi, I'm having problems with timing simulation in Modelsim. I compile and sythesize in Precision and I do the map and route in Quartus. Once I have the .sdo, .vho and testbench files I tried t...
15 years agoThe error log says that some instances are not found.
Did you check that they're present in the design files? Your post is entitled 'timing simulation'. Do you mean that RTL simulation is working for the same design?
