15 years agoTiming requirement not met after increasing NIOS frequency
Hello, We are designing a system that is successfully generated in SOPC builder and compiled in Quartus II. The system clock is 75 MHz and we need to speed up the NIOS II processing powe...
15 years agoadd an Avalon memory mapped pipeline bridge between the Nios data/instruction masters and the Nios JTAG debug module (not the jtag uart). The debug module without a pipeline usually slows down your system.
Then check if you should add more pipelines in your system. Multiple masters and/or multiple slaves connected together tend to reduce the max frequency of the system, and adding pipelines at strategic places can help increase fmax, at the expense of a higher latency.
