8 years agoTiming failure on internal paths
Hi dear, The design failing the time on internal paths and on the same clock domain. The timing report is attached as image . This design works fine without any constraints. Can p...
8 years agoHi,
Thank you for your reply, I have not written the design, the person who have written this code is retired now. I have written a short description of the design attached as pdf file and also the constraints which I have written are also attached. I want to increase the speed / frequency of algorithm. The algorithm in design is working fine at 164MHz clock without any constraints and I was able to run it at 190MHz with the attached constraints. Please let me know if you need further information.
