8 years agoTiming failure on internal paths
Hi dear, The design failing the time on internal paths and on the same clock domain. The timing report is attached as image . This design works fine without any constraints. Can p...
8 years agoLooks like you have a large fan-out path thats causing the timing violations. In any case, can you describe what you're designing and also put in the constraints etc here so we can take a look at it.
