Timing_FA
Can you share with me the documentation that I can refer for timing closure?
- ai_responder
Community Manager
Could you specify the device family or tool version you are using for timing closure? This will help in providing the most relevant documentation.Note: To continue using AI Responder, please start your next inquiry with ai_responder
Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
Thank you very much.
- paramProd
Community Manager
ai_responder Cyclone 10 designs.
- ai_responder
Community Manager
Here's a practical summary of timing closure guidelines and optimization techniques for Cyclone 10 designs.
Timing Constraints — Get These Right First
- In an FPGA design flow, accurate timing constraints allow timing-driven synthesis and place-and-route software to obtain optimal results. Timing constraints are critical to ensure designs meet their timing requirements, which represent actual design requirements that must be met for the device to operate correctly. Cyclone 10 GX Device Design Guidelines
- Quartus Prime optimizes and analyzes your design using different timing models for each device speed grade, so you must perform timing analysis for the correct speed grade. The final programmed device might not operate as expected if the timing paths are not fully constrained, analyzed, and verified to meet requirements. Cyclone 10 GX Device Design Guidelines
- A comprehensive static timing analysis includes analysis of register-to-register, I/O, and asynchronous reset paths. It is important to specify the frequencies and relationships for all clocks in your design. Use input and output delay constraints to specify external device or board timing parameters. Specify accurate timing requirements for external interfacing components to reflect the exact system intent. Cyclone 10 GX Device Design Guidelines
SDC Constraint Checklist
- Use
create_clockandcreate_generated_clockto specify the frequencies and relationships for all clocks in your design. Cyclone 10 GX Device Design Guidelines - Use
derive_pll_clocksto create generated clocks for all PLL outputs, according to the settings in the PLL IP cores. Specify multicycle relationships for LVDS transmitters or receiver deserialization factors. Cyclone 10 GX Device Design Guidelines - Use
derive_clock_uncertaintyto automatically apply inter-clock, intra-clock, and I/O interface uncertainties. Cyclone 10 GX Device Design Guidelines - Use
set_input_delayandset_output_delayto specify the external device or board timing parameters. Cyclone 10 GX Device Design Guidelines - Use
check_timingto generate a report on any problem with the design or applied constraints, including missing constraints. Cyclone 10 GX Device Design Guidelines
Quartus Prime Timing Analysis Tools
- Quartus Prime includes the Timing Analyzer, a powerful ASIC-style timing analysis tool that validates the timing performance of all logic in your design. It supports the industry-standard Synopsys Design Constraints (SDC) format and has an easy-to-use GUI with interactive timing reports. It is ideal for constraining high-speed source-synchronous interfaces and clock multiplexing design structures. Cyclone 10 GX Device Design Guidelines
- You can use the Early Timing Estimation feature to estimate your design's timing results before the software performs full placement and routing. On the Processing menu, point to Start and click Start Early Timing Estimate to generate initial compilation results after you have run analysis and synthesis. Cyclone 10 GX Device Design Guidelines
- You can use the
report_datasheetcommand to generate a datasheet report that summarizes the I/O timing characteristics of the entire design. Cyclone 10 GX Device Design Guidelines - Quartus Prime also supports static timing analysis in the industry-standard Synopsys PrimeTime software. Specify the tool in the New Project Wizard or the EDA Tools Settings page of the Settings dialog box to generate the required timing netlist. Cyclone 10 GX Device Design Guidelines
Fitter & Optimization Settings
- When the Optimize Multi-Corner Timing option is on, the design is optimized to meet its timing requirements at all timing process corners and operating conditions — helping create a design implementation that is more robust across PVT variations. Cyclone 10 GX Device Design Guidelines Enable this via Fitter Settings in the Settings dialog box.
- Physical synthesis optimizations make placement-specific changes to the netlist that improve results for a specific device. You can optimize for performance and fitting in the Physical Synthesis Optimizations page of the Settings dialog box. These options typically increase compilation time significantly but can provide significant improvements with push-button optimizations. If you turn on these options, ensure that they do improve the results for your design; if you do not require them to meet timing requirements, turn them off to reduce compilation time. Cyclone 10 GX Device Design Guidelines
- The Optimization Advisors provide guidance in making settings that optimize your design. On the Tools menu, point to Advisors and click Resource Optimization Advisor or Timing Optimization Advisor. Evaluate the options and choose the settings that best suit your requirements. Cyclone 10 GX Device Design Guidelines
- The Design Space Explorer (DSE) automates the process of finding the optimal collection of Quartus Prime software settings for your design. The Search for Best Performance and Search for Best Area options use a predefined exploration space to target design performance or area improvements with multiple compilations. You can also set the Optimization Goal to Optimize for Speed or Optimize for Area using the Advanced tab in the DSE window. Cyclone 10 GX Device Design Guidelines
Incremental Compilation
- Use the incremental compilation feature to preserve logic in unchanged parts of your design, preserve timing performance, and reach timing closure more efficiently. You can speed up design iteration time by an average of 60% when making changes to the design with this feature. Altera Cyclone 10 LP Device Design Guidelines
Speed Grade Selection
- The device speed grade affects timing performance, timing closure, and power utilization. There are two speed grades available for Cyclone 10 GX: 5 (fastest) and 6. One way to determine which speed grade your design requires is to consider the supported clock rates for specific I/O interfaces. Cyclone 10 GX Device Design Guidelines
- You can use the fastest speed grade during prototyping to reduce compilation time, and then move to a slower speed grade for production to reduce cost if the design meets its timing requirements. Cyclone 10 GX Device Design Guidelines
Synchronous Design & Board-Level Considerations
- In a synchronous design, a clock signal triggers all events. When all registers' timing requirements are met, a synchronous design behaves in a predictable and reliable manner for all PVT conditions. You can easily target synchronous designs to different device families or speed grades. Cyclone 10 GX Device Design Guidelines
- You can configure board trace models of selected I/O standards and generate "board-aware" signal integrity reports with Quartus Prime. When Enable Advanced I/O Timing is turned on (Timing Analyzer page in the Settings dialog box), the Timing Analyzer uses simulation results for the I/O buffer, package, and board trace model to generate more accurate I/O delays and extra reports. You can use these advanced timing reports as a guide to make changes to the I/O assignments and board design to improve timing and signal integrity. Cyclone 10 GX Device Design Guidelines
- To ensure reliable timing closure to and from the periphery of the device, you should register signals to and from the periphery before you connect any further logic. External Memory Interfaces Cyclone 10 GX FPGA IP User Guide
Reference Clock Selection (LVDS/SERDES)
- Use a dedicated reference clock input within the same I/O bank — this is the best choice to avoid performance and timing closure issues. Do not manually promote the reference clock. Cyclone® 10 GX Core Fabric and General Purpose I/Os Handbook
For deeper training, there is also a production Quartus Timing Closure Masterclass — an advanced course that equips experienced FPGA engineers with the skills and methodology to achieve reliable, repeatable timing closure on complex Altera FPGA designs using Quartus Prime. It focuses on diagnosing failure root causes, restructuring logic and pipelines, applying placement and fitter controls, and managing the full clock domain crossing (CDC) design space. Quartus Timing Closure Masterclass
